JAWIT
- February 13, 2019
- Richmond
- 2008 Mountaineer V6, 4.0L
Looked under the hood this morning to find coolant pooled in valley under manifold. 6 months ago I had the thermostat, thermostat housing, temp sensor, bypass hose, and both upper and lower hoses replaced, along with new Zerex G05 coolant. I put a socket on all the thermostat housing bolts but all seemed tight. All parts that I mentioned replaced were new Motorcraft. Could the housing have developed a leak somewhere in that short amount of time? Also, the wrench light on dash turned on, on my way to dropping it off at the mechanic today. Coolant level was maybe an inch below the full mark on the reservoir.
Could the wrench light be caused by the coolant leak, perhaps fouling a sensor? Car shifting became erratic on the way to mechanic and power seemed low so I kept speed very low.
Thanks for any thoughts on this. Seemed to happen out of the blue!
