jongray1810
- January 5, 2012
I am new to the forum. I have an 4 Liter Explorer 4x4 SOHC XLT 1998.
Over the holidays I replaced the water pump and theromostat and a few dodgy hoses around them because the water pump was squeaking on start up and there was a leak on top of the thermostat housing that turned out to be due to the theromostat seal.
Got it all back together and it seemed fine - however driving out a day later the temp guage went off the dial, I stopped and found most of the coolant in the expansion tank. I gingerly opened the radiator cap and found it empty (naturally) - I filled it and emptied the expansion tank into a container and drove on ... all was fine. Next day same deal, just as the engine gets hot and the thermostat opens (presumably) the expansion tank fills and the temp guage goes off the scale. I am carrying a 'fix it kit' and stopping every trip when the engine starts from cold going through the same charade of filling the radiator and emptying the expansion tank.
I have tried ...
- burping the car (uphill slope, open radiator cap while heating up with heater and AC on)
- checking the thermostat is in the right way round), belt is on correctly etc
- put the old thermostat back in incase I bought a wrong one
- replaced the radiator cap
Another odd thing is when I put the old thermostat back in and when I replaced the radiator cap the car worked fine for 1 - 2 days then this starts all over again.
No significant leaks and the coolant is where it should be each morning.
The pump that was sold to me was listed for a 2 wheel drive model not a 4x4 however it was the only one with the right hose fittings and it fits the manifold.
Bottom line once hot and 'replensished' the thing seems to work fine although I have only driven 25 mile journeys. Clearly some sort of overpressure .... any ideas?
I have tried ...
