Ya gotta get behind the instrument cluster. There are several steps to the job, but definitely doable. Do a search in this forum. While you're in there you may as well replace ALL the bulbs (#194's I think)...if one's gone the others will soon follow.
Most importantly, be sure to disconnect the battery and wait about 15 minutes to avoid an accidental driver's side airbag deployment. You'll be sitting right there doing the work and if that airbag goes off it could break your neck!
