Greets again,
to recap I recently put my A4LD back in after my first attempt at rebuilding...
I had transfer case in a bind, so things were complicated...and the transfer case was leaking.... these were minor issues...removed the bind, looking for gasket for BW1354..if not will use permatex, reinstall to fix leak.
I dropped rear driveshaft, attached pressure guage to test port , and tested pressure in all gears. I also checked for movement of transfer case where rear shaft attaches in each gear. I tested each gear at idle, (idle seemed a little high), and at 2k rpm. These are my results:
P R N OD D 2 1
Idle pressure 180 190 175 160 160 170 170
2k rpm pressure 185 380(>220) 180 200 180 180 180
Movement N N N Y Y Y Y
Seemed like tons of pressure, reverse soared to 380 when I brought rpms up to 2k, but then started cycling, it would get to 380, then drop to 220, rise to 380 again, drop to 220....over and over.
I am thinking that since I had movement in man 1, it is not simply the low reverse servo, (I changed seals on this from rebuild kit..but the seals were just typical oring type, same as it had before rebuild)... but tommorow I guess I will drop pan, remove the servo, and inspect...see if I can verify that reverse band is still in place..I checked it by looking down beside intermediate assembly with a flashlight..before I reinstalled center support. It appeared OK..., and I put low reverse servo in to hold it , before I took trans off of stand , but when I went to install valve body with trans laying with pan side up, I had to remove servo, and reinstall on top of seperator plate.... I did not try to visullly confirm that band was still in place then....
If anyone has any advice or thoughts on this...any help would be greatly appreciated!
Respects,
Ragga
P R N OD D 2 1
Respects,
Ragga
