masospaghetti
- October 22, 2006
- Huntington Beach, CA
- 98 XLT, OHV, 4D, 4x4, 5M
The rear output shaft seal on my transfer case is leaking and I am trying to remove the driveshaft to change it. I'm having trouble breaking the four 12mm 12-pt bolts loose at the front of the shaft. I've tried an electric impact that claims 420-ft-lbs of torque with no success (it's worked on removing axle nuts). This was after I heated up the bolts and used Kroil penetrating oil.
Any tips here?
Thanks all...it's a 98 Explorer, 4.0 OHV, 4WD with 200k miles.
Any tips here?
