Some auto houses will loan tools out with a deposit. See if you can find a test kit that pressurizes your system. If there is a leak, the pressure will go down at a rate depending on the size of the leak. Check your cap and make sure no cracks in the seal, or just replace it. Some kits can test the cap also. Make sure there is no air in your cooling system.
