ahodges
- August 31, 2009
- Millbury, OH
- 1996 XLT - 347 S/C
I am having a problem with the engine cutting out for a second while acclerating between 40 and 50 mph. It does it so fast that if you weren't expecting it you would wonder, "what was that?" It is just enough to cause a drivetrain clunk in the transmission and driveshaft.
When the engine is cold, it runs normally, no problems. It only begins to do this after it has been run for quite a while and the engine is hot.
I also noticed that as long as I am moving faster than 40 mph and let off the gas to coast, and then hit the gas to maintain speed again it will do it. As long as I don't let off the pedal to idle, it will run normally (ex. 100 miles straight down the highway with no problems until I let off to coast).
I know it is the engine because my RPM's drop from what every they were previously at down to a 1000ish really fast and then back to what it was with the blink of an eye. Seriously if I were to blink I would miss it.
It is a 96 explorer with the 4.0 OHV. 125,000k
Thoughts?
Thoughts?
