NHarris
- May 31, 2010
- Gillette, Wyoming
- 04 Wrangler, 08 Ranger
--Don't know if this has ever been posted up, but I found it quite interesting. So I thought I'd post it up for everyone.
--I think this would be the appropriate section. My apologies if its not.
--The basic engine dimensions for many ford engines. It has listed the bore, stroke, bore spacing, main journal diameter, rod journal dia, con rod length, cranskshaft center line to deck, compression distance (piston pin to top of piston).
Hope you all will find this as interesting or as informational as I did.
Probably best just to use the link to the PDF:
Ford Racing Basic Engine Dimensions
All the information is in inches, just use this formula to convert it to centimeters: in. x 2.54= cm
Thanks for viewing,
Nate
Thanks for viewing,
Nate
