bigorange440
- November 29, 2005
- ABBOTSFORD B.C
- 94 EXPLORER LIMITED
got a 94 ploder that im putting in the 6 inch skyjacker lift and ext radius arms..im putting it all in and i have run into a problem the drive side diff will not line up..if i put the diff into the drop bracket i can not get the radius arm into the bracket and if i put the radius arm the bracket in i cannot get the diff into the drop bracket...anyone else had this problem...i can see the radius arm is hitting the diff right near where that bolt goes in to hold the front carrier.. it needs to go in more but will not...should i just shave a bit of metal or am i missing something...thanks
