- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
A few months back I started playing with the free version of Google Sketchup. One of the things I drew was this fire extinguisher mount based on some I saw online. It is pretty basic mainly cause I was not sure how well everything would work and did not want to spend a ton of time on something that might not work. Here is what I came up with.
I knew Brian1 from this site had a CNC Plasma Table. So after a few emails back in forth I was able to create a .dxf file that he could use to create the parts. One of the things is that the free version of sketchup does not let you export as .dxf. I found a plugin online that allows you to export as .dxf. Here is a screen shot of what I sent him.
A few days later a USPS flat rate box shows up with these in it.
I originally was just going to use a pin but decided to order a bling pull pin from Mcmaster carr.
After welding them up this is what I came up with. My welding location is currently in a highly flammable mountain area so I plan on doing the finish grinding elsewhere.
Some of the things I discovered. Allowing 1/16" of slop between parts was to much. 1/32 or a bit less would have been better. I also miss having my welding table and garage with all my tools in it. A tailgate and no clamps or magnets suck. Looking at the parts now I probably would have made the base bigger so it would be easier to mount on a flat surface. The knob version of the pull would probably be better then the T that I bought. Overall I am happy with it and want to give a huge thanks to Brian1 for cutting the parts for me.
