First Gen 4" Front end lift from Explorer $250 + shipping
Includes springs, stainless brake lines, 3.5 drop pitman arm, front rancho shocks, and drop brackets only. 'Dannyboy' mentioned on Post #15 it's a Trailmaster - be sure to read his post. I purchased it used - the picture is when I purchased last spring and was told it was removed from an '87 Ranger. I'm upgrading to an 8" lift. The steering linkage and swing arms pictured are not included (not that you need them), nor are any rear lift parts included. You will also need extended sway bar links - depends on your setup. May need some hardware to bolt to frame, I'm not sure - I'll send as much extra bolts/nuts as I can. Uses standard radius arms.
*Update 11/6 11:15am EST: It will include 50% of the Hardware, but I've sweetened the pot with Front Rancho shocks (Purchased new in Sept/2011) and the Stainless brake lines*
The setup pictured: SOA rear, and I used the F150 spacers up front to have any overall height of 5.5". It was alignable and drives fine. Bump steer is a little squirrely - not to bad, but noticeable.
Will not be available till after 11/6.
