vloveone
- May 16, 2013
- raleigh, nc
- 2002 ford explorer EB
Hello all, new here and I'm looking for some serious help. Let me explain what's going on.
I have a 2002 Ford Explorer Eddie Bauer V-6 with 150K miles on it. Last month just out of the blue the CEL came on and the car started idle rough. The codes I get when i toke the car to AutoZone was P1131,P1151 & P0300
Day 1 - I change the spark plug wires. Wire plug #2 have a slice in it (I just did a Tone up and replace the wires and spark plugs about 6 months ago) the wires still under warranty with autozone so no problem with that. The spark plugs looked good and the gaps was fine. I also ended up cleaning the MAF and the IAC. I also replace all four O2 sensors. At the end of the day still had rough idle and the CEL still on.
Day 2 - After looking around I did find a vacuum leak a small hole on the plastic part of the Engine Intake Manifold. I seal it and the rough idle now gone and my CEL is off (No Codes)
Now here is the problem I can't figure out -- no power/fast acceleration. If i push down on the gas pedal hard the car act like it dont want to go. If i gradually give it gas it go fine switch gears i can get it up to 70-80n with no problem but i have to push on the gas pedal gradually if i push all the way down on the pedal quickly the car rev up but dont really go. when i have the car in park and push down on the gas pedal the RPM goes up nto about 4000 - 4500 RPm and act like it what to cut off
I have change the Gas filter but dont know what else to try any one can help me ??
