99SportX
- May 14, 2003
- Duluth, MN
- 1999 Ex & Mounty
Ok guys, I am at a loss here. I replaced the front pads and rotors in my dad's 99 mountaineer V8 AWD. The pads are ceramics from Napa. Everything was great until a couple days afterward, it developed a loud squeal. I narrowed the noise to the front right wheel.
The squeal does not occur right at first, but when things warm up it is constant when the vehicle is traveling faster than a crawling speed. The squeal occurs whether or not you are on the brakes or off the brakes, no matter how hard. Forward and reverse, the squeal is still there. Am I right to assume that if the caliper was dragging, the sound would go away under hard braking? We ran the vehicle like this for a week or so because we hoped it would go away. I took everything apart and lubed all contact points with synthetic caliper grease...no change at all.
I don't know what to do. Could it be a wheel bearing and not related to the brakes at all? I don't know if I should bring the pads back to Napa or not.
Any help is appreciated. Thanks.
