2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Engine ground?
The alternator output and regulator are dependent on a low resistance electrical path to the battery negative terminal. The alternator has no ground terminal. Internal components are grounded to the case that bolts to the mount that bolts to the engine. The engine has straps that connect it to the chassis and the battery negative terminal has a cable that connects it to the chassis. I suggest that you measure the resistance between the battery negative terminal and the alternator case to eliminate that a possible problem.
