- April 3, 2008
- Gloucester City, NJ
- 98 2Dr,2,000 & 04 4dr xlt
Fuel Injector Sizing
x is multiplication symbol
/ is division symbol
For naturally aspirated engines there is a fuel injector sizing equation all over the internet and also found in books written by respected experts in the field. The equation is this:
horsepower x brake specific fuel consumption / (.8 x number of injectors)
Note that horse power would be crank horsepower, not wheel horsepower
For boosted engines there is a different equation I have come across. It goes like this:
airflow cfm x .44298 / number of injectors (possibly x .8 for 80% duty cycle of injectors?)
To get CFM for a boosted engine:
cubic inch displacement x max power rpm x naturally aspirated volumetric efficiency x pressure ratio / 3456
My max horse power is at approximately 5200 rpm's (see first picture below)
Naturally aspirated volumetric efficiency of a two valve engine is approximately .85 (85%)
To get pressure ratio:
Atmospheric pressure + boost / atmospheric pressure
My pressure ratio:
14.7 + 16lbs boost / 14.7 = 2.09 pressure ratio
So on my engine....
244 x 5200 x .85 x 2.09 / 3456 = 652 cfm
652 x .44298 / 6 = 48lb injectors
if I use the .8 x 6 injectors to be at 80% duty cycle then....
652 x .44298 / 4.8 = 60lb injectors
So how does this math check out in the real world?
I have 60lb injectors and have just checked to see what the duty cycle was on them at WOT.
If this formula is correct (I think it is)....
Fuel PW in clock tics / (number of cylinders x time between pip edges in clock tics)
Then according to the datalog at around 6,048 rpm's.....(see 2nd picture below)
2290 fuel PW / (6 cyl x 605 Time between pip edges) or
2290 / 3630 = .63 or 63% duty cycle
I also checked at 5200 rpm's to see if injector duty cycle was higher, according to the numbers it was around 58% duty cycle.
So my 60lb injectors are running at most 63% duty cycle. Preferred would be 80%, you do not want 100% because it would be bad for the injectors and PCM.
So why am I going through the trouble of all this?
I want smaller injectors.
One of the oxygen sensor test called the rapid response test wont run/pass with the 60lb injectors installed. (see 3rd picture below)
I have to go through inspection once every two years and the last time I had to put some older 30lb injectors in to get the monitors to complete/pass. It sucks changing the injectors because I have to remove the supercharger.
This also has shown me that fuel control is not optimum at lower rpm's with the 60lb injectors, even though no codes ever set. I plan to try smaller injectors to see if the PCM will be able to run and pass the O2 rapid response test with them. I am wondering what is the largest size that the PCM will be able to complete the O2 rapid response test with. So far I know it will with 30lb injectors, and not with 60lb ones.
My pressure ratio:
So on my engine....
