newmab
- November 25, 2006
- Fair Grove, MO
- 97 Sport & 99 Eddie Bauer
fuel pressure bleed off
Just got through pulling pump-regulator out of the tank on our 99 SOHC. Thought the FPR was bad, so I checked with Ford. It runs about $60. After studying the regulator is has nothing to do with holding pressure. I assume the pump takes care of that.
But after seeing this thread: http://www.explorerforum.com/forums/showthread.php?t=66163&highlight=fuel+pressure
I did a little testing and found the factory clamps to be loose and the rubber hoses between the pump-regulator-outlet tube were deteriorated.
I'll replace the hoses in the morning and let you know the out come.
BTW, the issue I had was the vehicle was hard to start. Hot or cold. Unless you turned the key off-on a few times to cycle the pump. Fuel pressure when tested was 10 PSI after cycling twice KOEO. When I fired her up she sat at about 56 PSI.
