No I haven't replaced the fuel pump, just contemplating whether it is necessary now. I had it tested & wasn't building up the pressure that it should. When I removed the pump from the tank I tested the pump, where I could see it & noticed that it was leaking past the connections between the intank pump & a fuel presure regulator, Resonator/ fuel damper, not sure what it is called and have seen different people call it different things. It will build up to 55 lbs pressure with the old 12 volt battery, & was thinking that it might put out the required 65 lbs with the vehicle charging system working.
I can't blame the weather for my truck problems, I think I might just have a lemon. Know others with the same vehicle & engine with no problems. I have had 2 engines fail because of blown head gaskets & hydrolocking the engine (filling cylinder with coolant so they will not turn over).
By the way temperatures are still seasonal, by January or Feb we should see some -40 degree temps. I try to run a synthetic 0-30 oil in winter, or park it in garage or plug in the block heater.
Calvin
UPDATE: I just reinstalled my old pump after tightening the in tank connections. I started it up & could tell there was an improvement already. After taking it out for a drive & topping it off with fuel, I tested the fuel pressure at the rail @ 64 lbs. But it doesn't seem to hold the pressure for more than a few seconds after shutting the vehicle off. Before I done this work I had it in at the shop for a checkup they said it was only building up about 40 lbs of pressure, & wouldn't hold after shutting off. I will run a tank of fuel through it and see how it runs.
