PrideFool
- June 21, 2010
- 1996 Sport Trac
Here's my situation: I own a 1996 Explorer and I bought another damaged 1996 explore for parts (needed better leaf springs than the monoleafs on my daily driver). The donor had had a tree fall on it crushing the roof but other than that it was fine. I used the parts I wanted off the parts vehicle and now I want the donor to be a play toy.
I did not get the keys to the donor vehicle (nor a remote) so I took a hammer and screwdriver and tore out the switch. This made the alarm go off. I unhooked the horn and continued until I got to the point I could use the switch or what was left of it.
I then found that the explorer would not start with the switch (starter wouldn't turn nor would the fuel pump come on for the few seconds it should. I then checked to make sure it would run, I turned the switch to ON, unhooked the breather, got some ether, jumped the solenoid, sprayed in ether, it started and run fine as long as I gave it a squirt every second or so. I looked on this forum for clues (Love the forum btw) and found some. Checked the fuel pump shutoff switch (RF kick panel) first (it had been hit by a big tree!) - it was OK. Finally found what I think to be the alarm "brain" (RR panel above the wheel), I disconnected the biggest connector and I could get the starter to whirl but still no workig fuel pump. I then hooked the alarm back up to see if that made any difference. The alarm didn't go off this time and I could make the starter whirl but still no fuel pump. I then took the relays out of my running explorer and changed all of them in the power distribution box on the LF under the hood...no joy. Gave the tank a few "friendly" taps with a large hammer hoping to make the pump take off...nope didn't work. So finally, I registered here to ask people that know more than me, am I missing something with the antitheft system here? Just trying on here before I try some wire and a toggle switch.
Thanks much for any input
Jim
Jim
