sr acalito
- August 14, 2009
- Pinoy in the Kingdom Of Saudi Arabia
- '92 EXPLORER XLT OFF ROAD
Hello everybody! I am Acalito from Saudi Arabia, a new member.. Please somebody help me where to post this thread, last time brooklynbay transfer my post to new thread to where it belongs.. I have a problem with my '92 xlt. Last week i fill the tank full, at the gas station i hear like there's a motor knocking somewhere in the fuel tank, after running around 2 km, the engine stop & never start again, i cannot hear the fuel pump when i switch the key ON. I've read a lot of threads here, very interesting, so i decided to change the fuel pump relay but still the engine won't start. There are 3 relays under the power distribution box, i removed them all just to compare one from the another. This is what i've found: the green (fuel relay) normally open & the coil (two small pins) has 55Ω; the black (don't know what is this relay for) normally closed and the coil has 55Ω, same as green: brown (don't know what this relay for) is normally open but like a diode, there is a risistance of 80Ω, but if you reverse the leads of the tester, it's open. Are these an indications of GOOD relay? Please share your help.. Thanks in advance!
