buzzard73
- March 3, 2014
- Tacoma, Washington
- 2004 Ford Explorer NBX
I have fuse #15 blowing out constantly...I hooked up a test light to the fuse block in this location...light pulses. I checked the voltage, it shows 11 volts down to 10...battery os perfect, brand new and fully charged. If I put a new fuse in it blows out in exactly 4 seconds each time. I figure there is a bad ground somewhere in the circuit...but not sure where. The red light on the dash blinks when I hook up the test light...turns steady after I disconnect the light...so power is constantly going to this fuse, low voltage but higher amperage. Totally confused and scratching my head.
1. Dash gauges don't work
2. Windows don't work
3. Stereo died (CD player went out first)
4. Interior lights don't work
5. Fuse #17 under the dash is fine
6. Disconnected alarm to see if that was the problem
7. no broken wires in the door looms (Checked all 5, and fixed some cracked wire covers in drivers door.)
