GEM module | Ford Explorer Forums - Serious Explorations
GEM module
Goathead
Indian rocks Bch,fl
1999 mercury mountineer 4
Have 99 Merc mountaineer. Getting ready to replace module. No wipers, dome light, and seat belt light stays on. Wish me luck..
Pretty straight forward.
You probably need to remove, the center duct, too get at the top screw of the module. The lower screws on the vent duct, be careful not too drop the screws.
Take a picture before starting. Mark the connectors.
My module has three(3) connectors on the module , all have different pin numbers.
Once you remove top screw, the module slip up to remove.
About 15 minute job.
I thought when I pulled a GEM for my 96, it was just behind the radio, and easily removed…
Yes, its behind the radio area, on the left side . attached too a support or side panel( I can't remember. Its easy too removed. One screw. But the top screw is blocked by the vent duct. Look at your replacement. One slot.
