choppc
- December 9, 2003
- Greer, SC
I'm looking at doing a heater core replacement on a 1997 2WD Ford Explorer. I know that the heater core is leaking; the usual symptoms are present, including a sickly sweek anti-freeze smell when the heater is on and a film forming on the inside of the windshield, As I understand it, the late 1990's models require the dashboard assembly to be removed in order to gain access to the climate control unit.
Is this correct?
If it is, are there any caveats or other serious concerns [e.g. passenger side airbag] that I need to be concerned about when contemplating doing this replacement?
I have a fairly well stocked home garage w/respect to tools. I have a wide variety of sockets, wrenches, screw drivers, torx bits, etc..., but I wanted to know if there are any other "special" tools that I might need to do this job.
The various repair shops and Ford dealers that I called all said it would take 8 hours and would cost from $400 to $550. I don't have much $$$, but I do have time, tools and inclination to get the job done myself.
Is this correct?
