Heater Fan | Ford Explorer Forums - Serious Explorations
Heater Fan
nickrahn
Loganville, Wi
92 Eddie Bauer 4x4
It seems my heater fan only seems to work on high, click it one down and it goes off completely. any ideas?
i have the same problem. it happens in heat and ac.
Check the resistor block which is installed into the side of the airbox under the hood. It's a white connector next to the fan motor. It has resistors to provide the various speeds for the fan other than high. If it burns out only high will work.
So I took a look see and saw 3 connectors. before I start unplugging all of them, which one is it?
Pick up a climate control panel from the junk yard. $10-15 I had to replace mine on my 1994 with over 295,000 miles.
