jskingry
- September 24, 2002
- Tampa, FL
- 1995 XLT
Hello,
I do not post here very often but I have a couple of problems with my explorer. It is a 1995 XLT V-6 model. I just had the front brakes re-done, they replace the rotor which had gotten to thin and the pads, not the ABS is kicking in when I am braking right before it stops. It is a strong surging in the pedal and my stopping effectivness is reduced. Midas, the people who did the brake job said I need to take it to the dealer to fix it as if they did not cause the problem. I feel they have installed the incorrect rotors or munged up the sensors one, who really knows but is this something I can check easily?
Second problem, this problem has been with me for about three months now. One day my AC started to not be as cold or blow as hard, then I noticed on MAX AC it blows out the dash vents when I am decelarating and it blows out the defrost vents all other times such as accelleration or cruising at speed. The normal AC setting still bows out the dash but does not seem as cold or blow as hard as it used to. This does not really sound like the blend door problem, I was thinking a vacuum leak but cannot find anything upon initial inspection. Any ideas???
Thanks,
Jeremy
Thanks,
Jeremy
