Help needed with 04 Explorer | Ford Explorer Forums - Serious Explorations
Cdarwich
Bushkill, PA
2004 ford explorer
Hi my name is Bassel. I am having problems with my 2004 Ford Explorer and I am hoping that someone can help me and shed some light on this. The 4 x 4High is blinking and when you push the Auto or Low nothing changes. I have changed the transfer case motor and it did not make a difference. I have a code of P1824 which is 4WD Electric Clutch Relay Circuit Fault and I also have a C1234 Code which is for the Right Front Wheel Sensor Missing. My ABS light is also on due to the C1234 code. Can someone please help me?
Thanks in advance!
The New Member forum is for introductions only. For technical assistance please select the subforum which most closely matches your vehicle, or specific situation. You will be much more likely to get the help you need if you place your thread in the correct forum.:aerostar::exp:
