mplspug
- June 18, 2003
- Saint Paul
- MN
My 92 X won't start when the engine is warm, as a matter of fact, the problem has grown to include warm ambient temperature, even if the engine is cold. After reading posts, I banked on it being the Fuel Pump Relay so I replaced it. After putting everything back and attaching the battery and tried starting it right away. No FP prime. I am hearing a lot of relays clicking every time I turn the key, but if I don't hear the fuel pump hum and prime, I know it won't start. So the FP relay doesn't appear to be the culprit.
Any ideas?
I haven't read any posts where people have had to replace something along with the relay. Because it is temp related and it happens now with air temps +80 or so, I am guessing it is still electrical.
Some of my thoughts are the EEC relay, wiring to and from FP relay and computer chip. Maybe someone else has thoughts on a fuel pump not priming when it is warm out or the engine is hot. Also, can I swap my old FP relay that apparently wasn't the problem with the EEC relay. And is the EEC relay located on the far right as you look down on the fuse box.
Anyone with thoughts on how to troubleshoot the problem from here would be greatly appreciated.
Any ideas?
