joselama
- March 4, 2011
- Santo Domingo
- 2011 XLT
I installed HID on both fog lamps and headlamps. I had a problem with one of the ballast for the fog lamp and this blew the #47 (fog lights).
Also, i did not have high beam. If I hit the high beam switch, the blue light indicator in the dashboard turned on, but high beam was not activated. Also, fuse 39 (high beam) was OK.
I replaced the ballast for the fog lamp and replaced the #47 fuse. Fog lamps work great, but still no high beam.
When I flick the switch for high beam, blue indicator in dashboard turns on and fog lamp turns of (as they are supposed to). Fuse 39 (high beam headlamp) is still working.
If lights are OFF, when I hit the High Beam switch, lights turn on, but in low projection only. Does not goes to High projection.
I checked the plug and there is no current/voltage in the high beam wires. SO headlamps are ok.
I checked the manual for any other fuse or relay and I couldnt find anything. Any Ideas??
BTW: ALL fuses under the dashboard and in the trunk are ok. Tested one by one. This must be a hidden relay, wiring or module failure.
Im scared of taking it to the dealer because i think the aftermarket HID might have void my warranty. This is why im asking here first.
