Got back from a recent trip. Long story short I took out all the carpet and “rhino lined” the floors. It gets hot AF now. Any advice or suck it up?
It might help a little, but I still think you will get plenty of heat conducted through the floor it will still be just as hot. AC not work, or just doesn’t keep up?
I did the same thing few years back in my Expo. I just dealt with it but you can buy a form of aerogel and place it between transmission and body, will do the trick.
(Done this in a XJ and worked perfectly)
I played with the idea of bed lining my floor as well but settled on getting vinyl floor from a sport trac. Almost as easy to clean but I don't have the heat problem you describe.
Yeah I wanted something like the weather tech floor liners. Couldn’t find what I was looking for. Lucky for me the carpets were so nasty that it wasn’t a hard choice to cut them out.
I was expecting it to be noisy but never thought about the heat. I didn’t even pull up the rubber stuff that was glued to the floor.
I have about 100 feet of exhaust wrap left over from my bike I am going to use up under the floor where the rear cats that are still and always will be in place
I looked at the tunnel insulators from Jegs and I don’t think I’m paying that for one. I found something similar for like 30 buck online.
When I get home I am going to see how much room I have to work with under there, and if it’s too dirty for the adhesive stuff to stick.
For the weekend she might be getting a cheap carpet floor mat to protect her baby feets.
And I say Rhino Liner it’s the cheap knock off crap so maybe the thicker stuff would have been better for this.
A thin piece is sheet metal screwed to the tunnel with something to stand it off might make a huge difference. It’s the same principle as the heatvshields on the pipes and cats.
Ditto, it just needs a heat barrier between the heat and the floor surface material. The reflective sheet material might be best for the trans tunnel area, but how about at least a vinyl rug from a rare Explorer that had them. The jute material below the rugs helped a lot.
It went a lot further than the instructions said so it was an impromptu rip the rest of the interior out before it set. Going to be painted over anyways.
Not hard at all. Pulling the interior took the longest. It went on a lot thicker with the roller than being sprayed on so it will take a while longer to dry. But it’s going to be 106 here today so I bet it hardens quick lol
Yeah with it being 106 it will be done in like 2 hours right LOL!! I do not miss Texas at all. I was in Fort Hood Area for 4 years.
Well they lied and it was only 102 and a cold front of 97 tomorrow has moved in Everywhere I was stationed I always thought TX was better lol but it hot AF here and the older I get the more I like my AC
