antsmands
- June 8, 2012
- Chicago, IL.
- 2003 Explorer XLT
Changed both front hub/bearing assemblies on my 2003 Exp Sport yesterday. Not too bad of a job using the posts by SyberTiger as a guide. Using the spindle removal tool was a must to gaining easy access to the 3 hub retainer bolts. The most difficult part of the operation was removal of the hub as I forgot about the slide hammer until I actually needed it. After a few bangs to the old assembly to try and loosed it I finally used a flat scraper to cut the sealant which was helping to hold it tight and then successively pry bars until I finally got them loose. Some minor scratches to the hub retainer but nothing significant. I used antiseize on the assemblies as I installed them as there was also some corrosion due to moisture infiltration.
Glad I did the job as the right bearing was quite loose and growling and the left bearing was really getting hot as the spindle showed signs of heat load. I will have to keep my eye on this and replace the spindle if it shows signs of weakness from the previous bad bearing.
Front bearing noise is gone and the truck ride much more smooth and quiet. Now for the rears!
Thanks to all who posted in this tread. This was a big help!
