Bobs2018ExplorerSport
- February 4, 2019
- Location
- USA
- Livermore, CA
- 2018 Explorer Sport 4WD
- Callsign
- KD6ANY
In trying to understand the technology of how the factory-installed Engine Oil Cooler works, I've been told by my friend at Ford, as well as discovered through online research, that in the case of the late-model Explorers, coolant is taken out of the circulation path of the lower (cooler) radiator hose, and circulated upwards into an "Engine Oil Cooler" unit, which is a box-like unit that is attached to the side of a different Oil Filter Adaptor... where hot oil is circulated through (as is the coolant), thereby creating a heat-exchange effect. The coolant is then returned back to the lower radiator hose, to continue on its way into the engine.
