- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I need to go through my SOHC chains and tensioners again, given the 150k mileage. It is a shame that Ford made it so complicated and "fragile."
You have a very good system as it is now.
I haven't begun to upgrade mine, and I wish the auxiliary oil pump I have was still available, or any information about out. Mallory obviously stopped making it ages ago, and I never did find any references to the part number, which I keep forgetting. I'd like to know if it will work as intended, and if another could be found. It was only about $120 when new, but that was so long ago, maybe 1990, I forgot.
Your system is about the best that can be done feasibly. I'm going to need an oil tap from the engine away from the oil pump and sensor port, to accurately trigger the auxiliary pump. I have added an SS line to the back of my 347 block, from an oil galley plug to the rear top block deck. I'm not positive that the fittings cannot leak, which is why that's not a simple reliable thing to do. You'd hate to install an engine, and discover a leak between the engine and trans. I was going to use a hard line, but later decided on a flexible line so that the ends could be swivel fittings, less likely to "wind up" when assembling it(tightening the fittings).
