Good stuff. How do you like it?
I picked it up and it is a little higher up front. It lifted it more than I thought it would. I am going to see if it settles any. If not I am going to get some for the rear from RB.
I took some pics and will post them tonight. I snapped some close ups of the area with the spacer installed. It looks fine to me with none of the issues where stuff is rubbing.
how much did they charge you, and what was the name of the shop?
Thanks
Chris
One minor question, has anyone re-aimed their headlights to compensate for the lift?
Since a lot of us are buying these I thought it might be good to have a thread dedicated to installing them. I think we had a "how to" thread on this at one time but I could not find it.
I am in the process of putting 2" spacers on the front of my explorer. So far I can say that you have to put your new bolts on the spacer before you tighten it down on the studs at the top of the strut. It you put the spacer on first you can not get the bolts in. It may not be this way on a 3" spacer since it has more room.
Like everyone else I am struggling with getting the strut assembly compressed enough to get it back in. If I figure it out and have any tips I will post them here. If anyone who has already done it has any tips I would appreciate them.
Thelt - One minor question, has anyone re-aimed their headlights to compensate for the lift?
Here' what I did. For the front..
Support lower control arm with floor jack.
Disconnect sway bar, both sides.
Disconnect Upper Contol Arm (ball joint)
Disconnect Tie Rods (be careful not to hurt the castle nuts).
Disconnect upper bolts of strut assembly (Three bolts)
Disconnect lower strut assembly bolt. Let assembly hang.
(you may lower the floor jack)
Install spacer (It's true that you will need to install the new upper bolts before tighten down the spacer to the strut assemby).
Install the spacer end.
With the lower control arm hanging, install the lower bolt of the strut assembly (there may be some binding).
Raise lower control arm with floor jack (I used a spring compressor on one side and not on the other. Either is possible. If you go with no spring compressor, be prepared to use a lever to pull down the upper control arm enough to get the upper ball joint bolt started).
Re-connect tie rod ends.
Re-connect sway bar.
Feel free to add something I might have missed (I'm going by memory) or if you did something better/easier that I did.
This is where I screwed up. I tried to leave the sway bar, ball joint and tie rod connected. I tried to use the coil spring compressor to compress it enough to get it back in. That does not work.
If I had known I could get it done for $60 though I would not have bothered with trying.
Well at least you have them done now. And I guess the rest of us will know to take it all off before trying to squeeze them in there. I'm wanting to get mine soon but a buddy of mine is suppose to get a set of KMC wheels with new muds mounted on them for 250 bucks today. I told him they must be stolen!
Yeah, his old ones are pretty sweet.
