Can anyone HELP!!?I Love Love Love my trucks and wish I could fix them before I go crazy!
The 95 doesn't want to go into any gear not 1st, 2nd, or 3rd yet it still drives wherever I want it to take me. When it does go into a gear and I never know what gear its in, its because I forced it to by keeping the speed so high that it then jerks so hard it that I could get whiplash. I never quite know the speed because the speedometer no longer keeps true speed. When it goes out of gear the speedometer goes to '0' and stays there till it kicks back into a gear. Since I've had this 1 I've changed the transmission at lease 5 times in a 2 yr period. Can anyone help! I just want it fixed!
My 2000 just started making a jerking sound as if its putting itself into 4 wheel drive just for going over a bump, then that occasional noise under the back of the truck became an all the time noise. I took it to the Strauss and they told me that my rear differential had gone, I needed a new rear end & they didn't do that kind of work. My friend and I matched the gear ratio to one at a junk yard and he installed it, lo and behold the same noise! While taking it to the Strauss this time it wouldn't go into 1st, 2nd, or 3rd gear like the 1995 and when the Strauss guy test drove it we barely made it around the block. He said the purchased rear was a bad one to and that my transfer case is now bad as well. When driving it less than a mile back home I stopped to enter the highway and it wouldn't go anymore. Luckily, my daughter was behind me and pushed me with the 95 the rest of the 4 blocks home... I pray theres someone that can help.
On tuesday the junkyard will deliver the replacement rear and collect the 1st one and I'm guessing that my friend and I should be replacing the transfer case at the same time?!? Can someone help, before I break down in tears, burn them both and buy hondas!!
Thanx for any help
Camellia
