gshep12
- March 14, 2008
- NJ
- Explorer 04 Limited 4.6L
I was underneath my 4WD Exploda last Friday and was checking how the Front drive shaft felt compared to the Rear drive shaft. There wasn't any movement up or down or back and forth on the Rear Drive shaft. On the Front Driveshaft I placed my hand approximately in the center and I was able to move the drive shaft slightly up and down and back and forth, I assume this might be play. Can someone tell me if the front should feel this way? Should it be rigid like the Rear Drive shaft, with no movement at all? Based on sympton does anyone feel this could be a bad U-joint/ CV joint on the front? Could a bad U-joint/ CV joint produce a rumble sound at highway speed?
In addition I read on the Alldata website that a rumble noise can be worn wheel bearings. I"m aware that the front wheel bearing are known to go prematurely. Can they be worn and not have play? When the Tech checked them using the 12 and 6 o’clock technique he said there’s no play. To date I've had one rear wheel bearing replaced, which made no noise. What can be causing this horrible rumble sound that increases in amplitude as my speed increases? It is not the notorious Whine or Hum that the Rear Differentals produce. I'm running Bridgestone Alenza's on the truck; supposedly they're all balanced. I was told they have a slight hop on all four, I don't feel a lot of bouncing especially at highway speed. Could a hop produce an extreme rumble at highway speed? I have less than 30k on tires rated to last up to 65K; there is still plenty tread above the wear indicator. Any info on this will be appreciated.
