spta97
- June 12, 2003
- NY, NY
- 2000 5.0 AWD
Well I got the instructions and cleaned my IAC after the dealer said it was bad and wanted to charge me $225 for a new one to fix my stalling problem on cold days. I sprayed it until it was as clean as I could get with electrical parts cleaner and let it sit for an hour then blew some compressed air (from a can) to dry it some more (all while the negative battery was disconnected).
After putting it in it took a few tries with the gas to start it up. I let it idle for a little while as was reccomended and then took it for a road test. The one thing I noticed is that the idle seems much lower now (500 RPM) than it was before. As a matter of fact the 500 RPMs seemed almost too low (the lights would brighten up when I hit the gas). I tried stopping and starting it a number of times and instead of a big roar when it started it would hit 1,000 RPMs then bounce down back down to 500 RPMs - although this is once the engine was warm.
So did it work? I've got the hood open now to cool down the engine to see if it will stall on me but I'm not sure if what I described is normal behavior for a working IAC. Is the "learning" part why it stalled at first? I just wonder because I'll order a new one if cleaning didn't fix it. The true test will be tomorrow morning but I would love to get some replies tonight!
Thanks.
Thanks.
