Cherokee kid
- October 12, 2011
- 1995 Explorer
Great thread!
It saved me some bucks. My 1995 Explorer would run but wouldn't idle. I remembered that it had this problem several years ago and the shop replaced something simple and easy to get to but i couldn't remember what. It was the IAC.
So, I pried off the black cap, unhooked the plug and took out the two 10mm bolts. Lots of black crud on the piston shaft and spring in the upper chamber.
I used some gun cleaning solvent called Remoil, q-tips and an artist's brush. The brush was great to clean the valve and the valve seat and the spring. Obviously, the valve and the valve seat have to be clean to seal properly and the return spring needs to be able to move. I soaked the black plastic cap in alcohol to clean the felt pad and blew a little solvent through the brass tube. Get all these clean and your good to go.
The Remoil not only acted as a solvent but provides a light lubrication as well. Put everything back on and it idles smoother than it has in a while.
