thanks and i know i was going to the junk yard and they were gonna pull everything i need for $170 they were going to try to pull it all in one piece so i can just roll it under and bolt it up if possible
Was I this stubborn when i was 16?
You realize these trucks have IFS? It will not be one piece. I know from my experience this last week on my own truck that removing and installing IFS suspensions is not simple. Not to mention the special tools and knowledge you likely don't possess. Given your experience level, you likely don't have the knowledge to pull this off with out a map of how everything goes back on.
If you are hell bent on doing this, you have a higher chance of success if you yourself remove from the donor vehicle. Furthermore, i would recommend that before you do that, you remove the front suspension from your truck. That way you can bring home your new one and bolt it one while everything is fresh in your mind and you have the experience of two removals.
By the way, the tie rods are different as well. so you will have to remove everything from the pit-man arm. I'm not sure about the arm and steering box itself. You will of course need an alignment.
Then there are costs like the brake rotors, brake pads, You should put in new bearings. Hope your junkyard calipers aren't locked up. There will of course be unexpected expenses. Bad bushings that need to be replaced and the like.
If your going to all of this trouble, you might as well swap in front from the 97 Ranger with the dual piston brakes. But like everybody else has said. Just drive it. They are reliable trucks, you never know when you will need 4WD. And as a forum members sig says "99% of the world is unpaved, it just makes sense to own a four wheel drive".
You will gain nothing by lowering this truck (if you succeed). Looks are not everything. Just look at Pamela Anderson. A shell of a person that looks worse after all the mods. Granted she has more miles than your truck, but still.
I know you think this is the right thing to do. but your wrong. It's ok to be wrong. Your 16. you will be wrong thousands of times before your 18. It's alright to admit your ideas are crazy brained. Sixteen year olds think with their dick. Hell, I still think with my dick and I'm more than twice your age. But, the difference is I have 20 more years of my dick getting my in trouble, so now I can tell (some times) when to not listen.
In this case, you should not listen. Just wait to do this mod in 4 years. If you still feel the same way, I'll box up all my tools and come help.
Instead, consider this option. Take the money you were planning on spending on this swap, then double or triple it, because that is more accurate estimate. Now take that money and buy a bad ass stereo. 2 12s, 6.5s in the doors, 500w sub and 150 watt mids and highs. You will get more enjoyment from that than you will avoiding every minor dip and crack in the road.
Don't do it!
