JakePSD
- March 25, 2010
- Ohio
- 2003 Mercury Mountaineer
Who can identify this piece? Truck is an 03 mountaineer. It was stuck to the magnet in my trans pan.
A little history. Bought the truck in October with a blown motor. Was told there was nothing else major wrong with it. That's kind if a half truth. I finally got the replacement motor in last weekend and noticed that, although it doesn't slip any in gear, it shudders when shifting some times. Most noticeable on the 4-5 shift. My 02 ex I have started doing the same thing shortly after I got it, so I drained and refilled the pan which solved the problem, shifts perfect now. So I set out today to do the same to my 03 plus a filter change.
So I dropped the pan to change the filter today on the 03 since I have no idea when it was last changed. 281xxx mi on the odometer, although there is a blue tag on the trans that says remanufactured and has some numbers. I can get those if anyone has the ability to find any info on mine. Supposedly the transmission fluid was changed about 100k ago. Looking at it I kinda believe it. Pretty dark, but doesn't smell burnt or anything. I found a steel piece stuck to the magnet. Besides that chunk, the amount of stuff on the magnet didn't seem alarming to me, seemed pretty normal.
So what do you guys think? Where did that piece come from? How much more life should I expect out of this transmission? Stuff on the magnet seem normal to you?
