C Jeff
- January 19, 2001
- Indianapolis, IN
- '95 Ex Expedition 2Dr
I have a 95 with control trac 4WD which means when in 4HI the front wheels only engage when the rear wheels spin. The funny thing is when I switch into 4HI in about 1 to 2 minutes the lights, 4HI & 4LO, blink 6 times and go completely off, but the EX feels like it is locked in 4WD. Moving the switch does nothing to either put it back into 2WD nor does it turn the 4WD light back on. The reason I believe it is locked in 4WD is the rear wheels do not spin on wet pavement and I can feel the front wheels drag if I turn sharply. However I can get it back into 2WD when I stop put it into park and shut it off. It also does the same thing in 4LO. As a side note it did the same thing several months ago just minutes before my transmission went out. I also run the transfer case once a month in both 4HI and 4Lo to keep everything working. I am confused as to what I need to do.
