o6tnineo
- April 3, 2001
- Omaha,Ne
- '05 Explorer XLT 4.0L
I have an 05 XLT and it is completely stock with the exception of a newly added KKM filter kit. Before I installed the kit, I noticed a slight whistle under the hood that appeared when there was a load on the engine around 2000-2300 rpm. After the install, the whistle sound is much louder but still only appears around 2000-2300 rpm. It does not matter how fast or slow I am going, it always appears around the aforementioned rpm range.
I had a 96 X that the IAC hummed at idle, which was easily repairable and this sound is much more a whistle than a hum.
And to my knowledge, the gen 3's (drive by wire) systems do not have an IAC. (so that can't be the culprit) I have tried both restricting and removing the crankcase vent line. (the end connecting to the air intake tube) and that did nothing to affect the problem. The only thing left that I have not tried yet, is cleaning/replacing the pcv valve. Does anybody know where it is located (pics!?) on an 05 XLT?
Additionally, I know that many people before me have had this problem, has anybody managed to figure this out? Is it just air rushing through the filter and therefore un-fixable?
Just to reiterate:
1) It is a whistle that got louder when KKM kit was installed.
2) It is not the IAC.
3) It is not a rear diff or front diff whine.
4) Where is the pcv valve on an 05 XLT?
5) Has anybody fixed this issue before?
Just to reiterate:
