holter95
- September 17, 2000
- MPLS, MN
- '01 Mountie V8 AWD
Installed 2 plugs last week in my trans pan (1 for drain, 1 ready for an oil temp sensor). One of the two I'm sure I overtightened - I torqued to spec but felt the plastic (nylon?) washer crush before I hit the suggested torque. Both are leaking from the outside threads.
Question: Would RTV have any adverse affect on Mercon ATF (or vice versa) if I used that to better seal up the drain plugs around the washer?
