slsmith
- March 20, 2004
- Albany, Oregon
- '91 Eddie Bauer
stock '91 Eddie Baugher with 215k miles
Ok.
For the last couple of months I have had an oil leak which I tracked down to a bad valve cover gasket.
Now I still have a leak, but it does not appear to be oil. I have looked over my transmission with no luck finding anything. Yesterday when I started my rig I had a small backfire and as expected I blew a line off the vacuum tree. When replacing the vacuum line I discovered that it was a gooey mess and appears to have brake fluid in the tree. It seems to be leaking down over the valve cover and onto the exhaust.
I am assuming that I have issues with the master cylinder and maybe also the booster.
What do you think?
Thanks
Steve
Ok.
What do you think?
Thanks
Steve
