bradley9101
- May 31, 2012
- Chattanooga, Tn
- 2005 Ford Explorer
I have a 2005 Ford Explorer Eddie Bauer...it has dual electronic climate control...When running the AC I get cold air coming from the passenger vents and hot air from the driver vents...What is causing this? I thought after reading and reading that the blend door actuator was broken so I look apart the dash to replace it...before I unbolted the actuator, I turned the car on and changed the temp from hot to cold and cold to hot several times...it appears that the actuator is working because I can see and hear the square spindle rotating as I roll from hot to cold...Am I right? is the actuator working right? What is my problem? Thanks!
