I've got a '13 Sport in SF with the tune, 3 bar sensor, plugs, thermostat, meth injection and oil catch can. Sounds like it would never pass smog right? Well, the stock 2 bar map sensor can be put back in a minute, the stock tune can be put back in another 10 (it clears all DTC codes first and the ONLY trace in the ECU is that the codes were cleared which can easily be explained), I installed the meth kit so it's basically invisible and the catch can can also be removed with no trace in 30 minutes. So, go for it! When you need to get it smogged, you spend an hour cleaning things up and there is zero trace. If you live around the Bay Area, PM me. I'd be glad to share knowledge.
