bile
- September 25, 2011
- Pa.
- 95 ford explorer xlt
Last year when this problem started, the knocking happened when the truck warmed up. And then when I went over speed bumps. And when the truck came to a halt ans settled,.you would hear one small knock. Once you pressed in the pedal to start again, you would get one small knock. Ford said it was the Steering Shaft. So I replaced it with a junk yard one. Everything went good. No more knocking. Now,just a month ago, the small knock came back again. But this time it progressed quicker than last time. I just figured it was due to the fact that the Steering shaft in there now was used. And it finally crapped out also. When I took it to Ford, they said they could not get any play in it like they did the first time I took it to them. And they put the same mechanic on it as the last time. I told them to replace the shaft I gave them anyway,.with a second used piece. Welp,.the knock is still there, and now the steering wheel is a lot stiffer and doesn't pop back into position well when I go around corners. I did try 2 non ford mechanics last year when the niose initially started, and neither could find anything. That's why Ford reeled me in when they so-to-speak found and bandaged the issue.
