Fabbed4d88
- April 10, 2009
- Grand Forks North Dakota
- 98 XLT 5.0
I did a serch and got alot of info on cam swaps...(Great info here I'm glad I found this site) I'm looking at Comp Cams XTREME ENERGY 35-349-8, The specs on this cam are:
INTAKE MASTER 3610F
EXHAUST MASTER 3611F
ENGINE FW XE264HR-14
GRIND NUMBER FW XE264HR-14
INT EXH
HYDRAULIC Y/N YES DUR @.050
212 218
INT EXH LOBE
LIFT .321 .321
VALVE ADJUSTMENT HYD HYD ROCKER RATIO 1.60 1.60
MAX GROSS VALVE LIFT .512 .512
DUR @ .006 TAPPET LIFT 264 270 LOBE SEPARATI 114.0
ADVANCE 4
VALVE TIMING OPEN CLOSE VALVE SPRINGS 986-16
.006 INT 22 62
EXH 73 17
THESE SPECS ARE FOR CAM(S) INSTALLED
110.0 INTAKE CENTERLINE
Any Input on this cam or recommendations on another would be welcome. Also, shoud this cam require new springs? I only have about 58k (original) on the motor. With the cam swap I would also run a set of rollers. Would this cam require a tune? I know Explorer Express had a Bama Chips tuner....is there anything else? I would like something upgradeable cuz I plan on adding TM headers and other things at a later date.
Thanks for putting up with a noobe question,
Fabbed
Oh yea...I have MAC intake and exhaust already......if that helps??
INTAKE MASTER 3610F
INT EXH
212 218
INT EXH LOBE
LIFT .321 .321
ADVANCE 4
.006 INT 22 62
EXH 73 17
Fabbed
