wsrzerotwo
- February 9, 2010
- SD CA
- '96 XLT 2.3L
ok, first off hello im new here and have found many helpful threads here and i hope you guys can help me with my specific problem..
so heres what i have:
96 ranger 2.3l (8 plug) 5 speed regular cab
i bought it off a friend of mine with a blown head gasket last year with 112k miles. here is what i did initially when i did the head:
fresh head with valve job
head gasket
plugs
wires
ignition coils
egr valve
evap solenoid
dfpe sensor
iac valve
tps
pcv valve
water pump
thermostat
ect
i basically did a pretty major tune up and tried to replace everything i though could and would wear out. it ran pretty good at first but i seemed to have the dreaded hesitation/stumbling problem that ive read so much about here.
a few months ago i noticed a crack in my cat and i had a smog coming up so i replaced that.
ive replaces most of the vac hoses and did a propane test to check for intake leaks and found none. it didnt really bother me at this point i pretty much got used to it, the truck never stalled and had good on throttle response. now it comes time to get it smoged in good ol california. i have a scan tool and could see that not all monitors were showing completed, but only four werent so i gave it a shot and passed with flying colors except failed because not all monitors had run.
so i got an extension and have been driving now for about a month and the monitors refuse to run. i have also tried to drive evenly and do some of the procedures to get the monitors to run (such as letting it warm up, drive up to 45 for 10 min, coast to a stop.... etc etc) and the monitors STILL refuse to run. i have put probably 500 miles in this manner, still no monitors. there have been no DTC codes whatsoever, however it seems to stumble still but idles around 6-700 rpm.
here are the monitors that will not run:
catalyst monitor
oxygen sensor monitor
oxygen sensor heater monitor
EGR monitor
this would seem to indicate the o2 sensors to me, but i dont want to just start replacing parts, especially because there have been no problem codes.
what do you think? any help/advice/experience you can share is much appreciated.
i only have a month left when i have to smog the truck (stupid cali will only give you one extension now) so i need to get this figured out pronto
head gasket
plugs
wires
ignition coils
egr valve
evap solenoid
dfpe sensor
iac valve
tps
pcv valve
water pump
thermostat
ect
catalyst monitor
EGR monitor
