wimpytwins
- November 29, 2004
- utah
- 93 explorer sport 2dr
i have a 93 explorer with abs. two years ago i put in a none abs rear axle and also a solid axle up front. it has been fine for the last two years and now out of no where my brakes dont work. when the car if off i can push on the brakes and the pedel get hard after a few pumps. when i start up the truck the brake pedel go soft and i can push it to the floor over and over. i have replased all of the lines and i have bleed them a dozen times. i have check for leaks and there arent any. could the abs modual just go bad? shoul i bypass it? what do i need to bypass the abs if that is whats it is?
thanks for the help
thanks for the help
