mccoyxx
- September 15, 2009
- Belfry,KY
- 1992 Explorer 2wd
Hey everyone ... I need some help A.S.A.P. ... I have a 96 Explorer Sport and am in the process of changing the upper control arm on the drivers side. I removed the nuts from the upper bushings and removed the bolt towards the front easily enough, but the one towards the right side won't come out ... there are wires and things that won't allow me to get in there to turn it enough to remove it ... also I can't get the balljoint to break free from the knuckle ... I used a 3lb sledge and beat on it every way i could imagine ... I lifted up on the hub, pushed down on it ... hit the control arm itself ... sprayed it with lubricant and then went at it again and its not budging !! .... I removed the nut from the bolt holding it and also beat the bolt HARD trying to push it through and it won't budge either .... HELP ME PLEASE !! ... thanks for your time ... RSM
