EBawd1998
- May 24, 2006
- montreal
- eddie bauer awd 5.0L 1998
hello every body ! i have a ford explorer eddie bauer awd 5.0 L model 1998
built in nov 1997 . it was runing pretty well until now but this last friday after a 1/2miles it doesn't want to go more than 10miles /h ( even 1, 2 and drive same reaction ) .big problem! i turn it off and start it again the power come back for 2 second and after same problem ! no power! it can hardly climb an one degree hill ! it not seem to be affected on the reverse , the motor is turning very well on the iddle but refuse to go upper in the rpm when i put it on drive (but sound very well no noise no hesitation just doesnt go up in the rpm ! )
all the cylinders are working but the filling is like if only 2 cylinders were working . nothing special has been done on this truck untill it happen ! ford doesn't know what is happening, they just change many sensors and many parts without any result at higly cost! after the 5 time they plug it to the they computer they found a default crankshaft sensor so next part will be the crankshaft sensor (200$ more labor ) but they are not sure is the base of the problem and cannot garantee the job! even they plog it on the scan to test it , the first reading said short circuit, it has been fix but not solved the problem , the second test said , automatic solenoid transmission default , it has been fix too but no change, 3th reading said oxigen sensor fault , has been changed but the problem still there, 4 th said egr vaccum regulator fault , it has been changed and the computer reseted , ford was sure that the car was finally fixed but when we try it after 30 feet , the problem came back ! this car is driving me crazy and ford too , only thing they can tell me it is :we need to fix every trouble one after one to get to the real problem ! i have spend lot of money whitout result it is really frustrating! i beging to beleive that ford dealer is not really good because since the last fridays they work on it but no result ! i won't tell you how much it cost me! you could be scared if any one know what it is , please tell me every opinion are welcome at this point ! a couple of week ago i had a noise a low speed such a couic couic couic from 1mils to 15 miles /h but desapearing up to 15 miles/h, brakes has been inspected but nothing was found ! i don't think there is a relation between that and my actuel trouble! thank for your help !
